PhotonFanatic
CNC-123 Octagon Body Closeout
The time is nigh to clean out the closet in anticipation of the newer version, aka Groovy!, in the near future.
For those unfamiliar with the CNC-123, it is a single cell C123 flashlight that accepts standard drivers such as the Badboy, Madmax Plus, NexGen, etc., that Wayne Yamaguchi sells. These drivers are all .55" in diameter and .300" tall, not measuring the Luxeon, just the sandwich.
What distinguishes the CNC-123 from other homemade lights, it that it can accept a variety of optics or a reflector. It will take the NX05, the Fraen narrow beam low profile optic, and the IMS 17mm reflector after some trimming. When using the Fraen optic or the IMS reflector, it helps to use a 20.5mm diameter lens for protection.
The over length is only 3.32", the diameter is 1" at the head. The light weighs about 2.2 ounces.
The switch is a clickie, the Kroll switch is located at the bottom of the light, recessed so that one can stand the light on end while on.
Here is a comparison shot with some other familiar lights, CNC-123 HA is the third from the right:
Available colors, first the electroless nickel plated version:
The Hard Anodized Type III:
The Blue anodized:
And finally, the Black anodized:
Pricing
EN plated, Blue Ano, and Black Ano: $40 each, three for $105
Hard Anodized Type III: $43 each, three for $115
Terms
Items will be mailed postpaid via First Class Mail in the U.S. Foreign orders please add $2 per order.
Some of these bodies do have some slight anodizing defects which is no way affects the mechanical working of the body, but should be considered cosmetic defects. All sales final. Sorry, no assembly service available for this closeout sale.
If you want or need additional items in order to complete the flashlight, then the following are available also:
Borofloat lens, 20.5mm: $5
Special O-ring for use with borofloat lens: $.50
IMS 17 mm reflector: $4
NX05 optic: $4
Fraen narrow beam optic: $5
NexGen 500 mA sandwich with TWOJ III: $55
Kroll tailcap switch: $5
Retaining ring to hold sandwich in place: $.50
PP with cash to: PayCashPal (at) photonfanatic.com
or
PP with credit card (please add 4%) to: fanatic (at) photonfanatic.com
The Blue anodized:
Pricing
Terms
NX05 optic: $4
or
