The_virus
I recently bought a Gerber Infinity Ultra, the first had an LED that was crooked so I returned it for a better centered one.
This new one has a way better, whiter tint than the original, so I traded up for sure. However I'm experiencing a minor annoyance with it. Every now and then I'll twist it on and nothing will happen. Giving it a good whack turns it on, but never completely solves the problem, eventually I will experience this again and have to whack it again.
Also, it occasionally flickers and sometimes will go out...again, a whack solves this.
Obviously some connection is being lost, like the battery contacts are not touching. The battery is in there pretty snugly though, so is this a common problem I can solve? I keep checking inside and the spring contact on the inside looks maybe a little compressed, but when I put the battery in, I can push it down a bit so the spring isn't crushed. The cap spring is fine, it was a teeny bit bent, but I straightened it out.
The only thing that looks suspicious that I can't really get at is the white ring of what looks like epoxy glue. It might be tapered a bit and preventing the battery's + end from making perfect contact with the spring in there.
Is this a common issue with Gerber Infinity Ultras? I love this light and EDC it, but constantly whacking it is annoying and I shouldn't have to do it at all. I could probably return it (again) and risk getting a much more blue LED, but I'd rather keep this one if all I have to do is pull the spring out a bit or something. Plus what guarantee do I have that this isn't a common flaw, and any new one I get will display the same issue?
Anyone with experience on this issue care to help?
