[ QUOTE ]
Kiessling said:
The MR-X is a LuxV though
[/ QUOTE ]
Quite true.
[ QUOTE ]
cy said:
ok, thanks, good to hear improvements VS marketing.
MR-X X3T has been running aprox. 1.5amps with no problems.
[/ QUOTE ]
Not sure why you decided to pull this out. You have 4 die in the Luxeon V, in a series parallel hookup inside the emitter such that each die is only getting 750mA, instead of the 1500mA, as in the new Luxeon part.
The significance of the new part is it is a single "point die", instead of four big die, which makes it behave much better in a reflector or optic, and thus it is alot easier to focus, and turn it into a tighter beam, that throws alot better than your Luxeon V.
The Luxeon V X3T in your Mr. Bulk has always had a rapid degredation mechanism ~500 hours common to all Lux V emitters/stars, instead of the 10's of thousands to 100 thousand hours of the 1 and 3W devices. It is well documented in the datasheet on page 1, both in the write-up and in the side bar. It is also
emphasized by being repeated
no less than 8 times in the datasheet.
http://www.lumileds.com/pdfs/protected/DS40.PDF
Further details show more specifics the rapid degredation on page 8 at 700mA, and your X3T is blasting 1.5A into the poor little sucker, leading to a much accellerated decrease in light output over time, just due to the massive amounts of current, which is pushing it even harder than what is shown there on the datasheet.
Then you add in the additional heat factor due to the total power of the 1500mA * ~7.2V = 11 Watts, 2X beyond it's design, which causes the whole flashlight temperature to rise, and the degredation over time mechanism is much accelerated from what is even found on the datasheet.
I never realized fools were pushing their stuff that bad.
I guess if you don't mind the highly accelerated loss of output, and just want something that is absolutely bright as possible, running everything on the bleeding edge of things, it's really no biggie.
Anyhow, lets go back to the Luxeon IV
Now there is the additional increase in light output efficiency of the Luxeon IV, 15-30% higher, which means you need less input power to reach the same brightness, and also more of the power goes into the photons, and less into producing heat, so you get a double whammy, more output due to efficiency, and less heat generated in the first place, also increasing efficiency of the output.
Significance?
Higher efficiency means you'll have 15-30% longer runtimes at the same light output level.
Less heat generated, humm, so with the same cooling that you had before, you'll produce 15-30% less heat in the first place, which means the flashlight body will be cooler, so the LED will be cooler, and you'll see even more output just due to the LED running cooler.
And on top of all of this...
The new Luxeon IV emitter can be soldered
by design directly to the heatsink, which even further reduces the Luxeon IV temperature, increasing the efficiency of the LED, yet again. (yes, I know some folks solder their Luxeon emitter slugs to the heatsink right now, but it is not common in manufactured lights).
With specific features to aid in centering the emitter in the flashlight, and more accurate placement of the die in the emitter, you end up with more precise alignment in the flashlight, which helps produce a more perfect beam (for our throw aficionados).
These factors (efficiency, less heat, lower thermal resistance, longer runtimes, higher accuracy, and precise placement features) add up to a awful lot, most especially stacked together.
There are even further improvements in the new Luxeon IV (that haven't been announced which add even further significant pluses) which equates for me (so imho), most definitely anxiously waiting for this new awesome part to hit the shelves, and certainly waiting to purchase any LED based flashlights, if I am at all concerned at all about performance. Basically any high dollar flashlight for me, I consider a performance flashlight.
I guess you could get assurances that the flashlight producer will retrofit the part into their design if you return the light, but some of the advantages, such as soldering it down, won't allow them to take full advantage of the part in existing designs. Some of the physical characteristics might preclude use due to the obvious mechanical aspects, without replacing or modifying the existing parts. To be safe, I'd get the maker to agree to some dollar amount to do the retrofit, ahead of time.
If I absolutely needed or must have the light -today- for a specific use where I couldn't wait, I'd personally just buy a low cost light, unless I was just buying it for a collection or something. But if you have way more money than you know what to do with, spend away.
Of course, on the other hand, collectors might want to gather up flashlights based on the old technology parts.
Rumor has it that these new Luxeon IV parts will be available for purchase shortly.
