[ QUOTE ]
Chop said:
The IMS reflector is plastic. That's why I mentioned the Aleph reflector. You could order from Carley with a phone call, but they have a $50 minimum order, which actually comes to 9 or 10 reflectors.
[/ QUOTE ]
As long as I not have to buy $50 of the same product I'm fine, I can spend the rest on bulbs.
Or is there anyone else that wants reflectors?
[ QUOTE ]
Chop said:
I mentioned the AA li-ion cell for a couple of reasons. The first is because it is my understanding that the Strion bulb is meant to run on a li-ion cell.
[/ QUOTE ]
I think the Strion bulb should work fine, both with a 14500 or with three NiMHs. Too bad I didn't order one in my last Brightguy order. One other bulb I will try out is WA1053.
[ QUOTE ]
Chop said:
The second was that I had assumed a cut down mini
m@g, without thinking about it. Sorry, I've just gotten used to chopping them whenever I needed one.
[/ QUOTE ]
Not everyone is lucky enough to have their own machining capabilities. Living in a small apartment I'm limited in what I can do myself.
[ QUOTE ]
Chop said:
In the end, the Carley reflectors may be the best route, but you'll need machining capabilities to fit the reflectors.
[/ QUOTE ]
I think and really hope that the Carley reflector I found is small enough to fit in there without modifications. According to the specs, it should be.
[ QUOTE ]
Chop said:
If you don't mind, I might like to pursue this a bit.
[/ QUOTE ]
I don't mind, hopefully you will be able to help me out if I get stuck.
Sigbjoern
