Weylan
I made a tap light a LED tap light.
I have a baby, well, a 2yr old now. We read at night till he falls asleep or play in the dark, some. After he falls asleep, we still need to see to not step on any "kitty landmines" or toys in the paths. I took a TAP light and made it better.
It runs 2x RED LEDs that work for the taplight.
It has 2xRED LEDs on the side for navigational use to get to the bathroom.
It has 2x WHITE LEDs on the side to help find particular toys that you need color recognition to find sometimes.
It has 3x NMIH cells, where before it would run off of 4 cells.
It has a switch for the side LEDs, so you can choose RED or WHITE.
The light has a 15ohm resistor per 2 LEDs. Probably I could get better run time if I picked better resistors, but this works.
I get a runtime of >2 week of use at 2+ hours of use a night, where I find that I then need to change out the batteries because the light "seems dim".
Over all a cheap MOD and easy light for less then $5 for the TAP light, some LEDs, a switch and some resistors.
