KDOG3
C2 lanyard ring won\'t rotate all the way around-
Also mentioned in another post, when you have a lanyard ring on the C2/M2 it won't go all the way around because of the pocket clip. That can be annoying... as you can see in my first pic, the pocket clip overhangs the ring area...
But not for long!!
Get out your Dremel with cutting blade and lop off that little "tab" that is bent down toward the light. Grind and round corners, cover up the scars with a sharpie. /ubbthreads/images/graemlins/wink.gif Viola!~ You have a shorter clip that allows the lanyard ring to swing freely.
But not for long!!
