jayflash
Being ham-handed & butter-fingered is a bad combo when not using a L-A-N-Y-A-R-D on your expensive, new, light. My E1L was exactly two weeks old on the last day of May when it decided to jump from my fingers into an air conditioning condensate drain in the floor.
It managed to squeeze between the numerous drain lines blocking the opening of the 4" pipe and shoot right through the trap about 4' below and into the horizontal line beyond the trap. It was on as it dove in, head first, and instantly, there was not a glimmer to be seen. It couldn't have gone too far beyond the trap but it was facing away just like it went down.
I'm trying to think of something stiff but flexible enough to tape a strong magnet to and hope it attracts the steel pocket clip. I have two very strong and small magnets that may work but haven't found the right transport mechanism. An electrician's fish tape is too stiff and curls straight up and doesn't go into the horizontal pipe after the trap bend. I'm thinking maybe the outer spring wire from a choke cable (what's a choke you may wonder). Perhaps the right plastic tube would be stiff enough to push the magnet up the trap and then lay down so it can touch the E1L. I'm guessing the light is aprox 5 - 7' away, maybe a foot or two past the trap.
I will appreciate any brainstorms - and thanks in advance for CPFers to the rescue.
