Re: Theory behind \"exploding batteries\" ?
[ QUOTE ]
cobb said:
Never had one blow, just the leak. No problems with cr123s, yet. Mainly with alklines.
With deep cycle and lead acid batteries they have vents. Wet cells or flooded can boil off the water and need to be refilled. Gel cells have a limited moisture in them and when its gone it is gone or so most say. I did read somewhere you may be able to add water to a dry gel cell and get mroe life into it, but havent tried it myself.
Those lead acid ones vent too and in fact if you over do it, you need to wait for the gas to vent before thebattery can continue making power. THis is why when your car wont start you crank it and it slows and stops cranking. After a few minutes you go to crank again and you have some extra power or the battery seems to magically recharge itself.
[/ QUOTE ]
very intresting... after i read this a fren of mine has this problem... i asked him how old is his battery, he says its only bout couple of months... I asked him if he had this problem before changing battery, he says no..
