Illuminated
Given the advent of the affordable BOG 3W SF drop-in modules and the popularity of using them in the SF G2's, I (like many others) had a desire to incorporate the 2-stage switch concept to make this combo the perfect affordable quality LED light.
I already had an older G2 (non-LOTC) with UCL lens from flashlightlens.com, and had also purchased the matching battery tube extender and battery spacer directly from Surefire. I had previously shortened the battery spacer to allow the use of the P90/91 LA's on 3 x 123's. This has all worked out just fine, but now I wanted the option of a 2-level setup that would allow me to run 2 x 123 or 3 x 123 battery setup in the G2 using the BOG 3W SF drop-in LED module.
McGizmo has already revealed how to adapt the McE2s module to the SF "Classic" in this thread here (Thanks Don), but this was only part of the solution to getting it to work in the G2. The button top for the G2 needed to be made from scratch (or modified from the original) so I made a new one to make the McE2s module and resistor board adapter ring work with the G2.
Now, for a few pics...
The results were quite satisfying. I chose the 30-ohm resistor board, as this seems to give a sufficient low level output using either the 2 or 3 cell configuration.
The bottom line is that I now have an easily convertible 2 x 123 or 3 x 123 setup based on the G2 that works quite nicely, 2-stage switch and all. I can also revert back to the incan setups if needed - so many possibilities with it now...
Of course, it won't replace my Aleph-1, but it'll certainly save some wear and tear on it, given that I don't have nearly as much invested in the G2 as the Aleph.
Thanks to all who contributed to the ideas used here (you know who you are...)
Also, thanks to Imageshack for hosting the pics.
John
John
