Sid Post
I never would have thought I would have ergonomic problems with a laser pointer but, guess what - that day has come.
I had a presentation that lasted about 2 hours which was 1 hour longer then anticipated thanks to a heckler who gave me the opportunity to demonstrate I really did my homework. Anyway, I had one of those laser pointers that everyone else seems to have. Normally I use a stick pointer but, this screen was about 16 feet high and ~40 feet wide and that was not an option. I was given a laser pointer which had a little silver ball on the barrel to turn it on. A few hits here and there were no big deal. As the presentation got buried into details, that little ball seemed to loose continuity in the circuit causing the beam to turn off. Beating the barrel in my palm helped marginally but, I found myself pressing harder to keep it lit. My thumb still has some numbness 3 days later but, each day the feeling gets better.
I am looking for the following features in a laser pointer:
<ul type="square">[*]One that has a large surface to turn it on for momentary contact
[*]A model that has a constant on
[*]A model that will burn for at least 2 hours continuous use without overheating or cutting out
[*]One with good ergonomic design
[*]One that won't slip out of my hand under hot lights
[*]One with a beam bright enough and large enough to show up on a bright screen
[*]Reasonable price
[/list]
Your help is appreciated!
[*]Reasonable price
[/list]
