S4MadMan
SOLD, thanks.
$160 shipped via USPSPMWDC. Not responsible for carrier negligence.
Paypal please. Shipping on in the U.S.
Get 200+ lumens of white LED light for 3+ hours. Never have to buy batteries again! Get this great, all-in-one setup which includes:
-One like-new Isaac Hayes modded Tri-Lux 3D Mag
-One like-new Vanson Speedy Box Battery Charger
-Three like-new MAHA PowerEx 11,000mAH "D" Batteries (3 cycles)
-Reflective as well as glow-in-the-dark tape on the handle for easy ID
Here are the specs per Isaac Hayes:
* Fraen Tri-Lens Optics (same as used in Elektrolumens Tri-Star-Phaser lights).
* .375" Thick Heat sink (1/4" + 1/8").
* Luxeon III bin SW0K x 3.
* Artic Alumina Epoxied HS & Lux's
* Set Screws. (head won't turn & break anything!)
* Beam is SUPER Smooth! No artifacts at all!
This works best with NiMH D cells for full power but Alks work just fine.
AA epoxied, and direct solder connections with multi-stranded wire for durability and reliable electrical contact. The head is set in place with 3 set screws, to prevent someone from turning the head and damaging the luxeons. If for some reason you wanted to open it up, unscrew the bezel, remove the optic, and 3 screws, then unscrew the head to get to the luxeons. Open at your own risk! The screws are really nice though as you don't have to worry about someone else picking up your light and turning the head and breaking something. Plus the head is rock solid and has no wobble at all!! This is super durable!!!
This is a first-rate mod and the output is excellent. Mated with PowerEx 11,000mAH Ds and a Vanson Speed Box charger, you have an all-in-one night solution. /ubbthreads/images/graemlins/smile.gif
