i thought this, but just based on conjecture.
if you can dissapate the heat well, on a LUXIII you can go to 150% and get 125% type light, anything over that is just a waste and when you get to 1500ma and over with a loose to the air star, it already starts to overheat and lower in brightness (for the current going in).
i get this from just dangling them about and cranking on them with voltage regulation and reading the amperage headed to the thing.
if it LOOKS brighter /ubbthreads/images/graemlins/smile.gif and its not gone up terrible on the meter , well then it IS, if it can stay that way airborn, it might be able to do that encased with proper heat removal.
so from my TOTALLY LOOSE estimates i say take it to 150% and get the bit brighter. take it OVER that, and hopefully you would do this for a shorter period of time.
IF by the time the thing is blazing hot, on a DD setup, the batteries have weakened, then its still ok to me.
when you say almost 2A, i say ok, but for how long do the batteries hold this for?
a light is kewl if it bursts up a bit when you first turn it on, and great when it slowly dies down when the battery is running out. as long as that is surviving the heat issue , then its FUN. if its overheating then it will soon be dimmer than anything you got :-(
that is all i know, i HAVE taken them to a full 2A (or is that a FOOL 2A) survived, and is as bright as the others still, but it was CERTANNLY overheating on the road to death, if i did that for a long time. Usually in Pannic , when i see it get that high, i cool it out within a few seconds.
just depends.
want me to FRY one , because that is rather hard to do.
that is all i know, they are hardy, when you go over spec it goes from a more Linear output to 50% that. so i would think from the eyes if you 200% spec, you get only 150% output.
i would prefer that it not go over 150% for any length of time.
at SOME point in over drive or overheat, you will get VERY POOR output for the current you put in, and mabey permanentally ruin it.
but even if you run SPEC and totally overheat it the same thing could occur.
so overdrive, if you can pull heat better. that is why on all my overdrives i make sure that the heat moves out very well.
sombody could probably do a chart, and i would suspect that it would go almost linerally up to SPEC, then start going down in Lumens per watt, then take a DIVE , when it baked into oblivion. what difference is that from a 5MM.
and if i was not Rambling enough
stating specific models and some arbitrary rate that somebody read on it at ONE MOMENT, doent tell ME anything about the lights TOTAL properties for surviving an overdrive, and it could change 100% or more, if your HAND was not on it leeching the heat into the human.
it can also change totally if this is only the burst rate, or if the light is only ever used for bursting.
also look at how that simple spring adds in major current changing resistance, also LEADS of the meter (wont mention WHOS
have Lots and lots of resistance, totally changing all the metered results.
if you want to know the average, not burst rate the led is REALLY being hit with, when its in a light and fully assembled, then check its RUNTIME with its capacity.
anything else can be subject to variations in the testing methods.
If it doesnt work, we will certannly HEAR the complaints right here /ubbthreads/images/graemlins/smile.gif
i have a few manufactured pieces of luxeon junk that i am playing with here now, and they did NOTHING for a heat sink, they underdrive, but its totally encased, with no good dissipation. it is as likely to die with the method they used, as the method i am about to torture them with /ubbthreads/images/graemlins/grin.gif
