winger
I noticed that I need to pretty much twist the tail cap ALMOST all the way clockwise (cw) until it cannot twist anymore before the lockout is disengaged (let me refer to this a 0 millimeter). Once I cannot turn anymore, I then have only about a 4 or 5 millimeter (mm) play counterclockwise (ccw) before the lockout 'sometimes' engages again. In other words, once I twist the tail cap about 5 mm ccw from the 0 mm positoin, sometimes the lockout feature engages; sometimes not. However, when the lockout is engaged at the 5mm position, I can normally still use the momentary on feature by pressing the switch slightly (but not all the way to click the switch on).
Note, that twist betwen 0 mm and 5mm is not too easy. It does not seem logical to me that a user needs to go that far for the lock out to disengage (e.g. allow light to click ON permanently.)
COMMENTS? DO I HAVE A DEFECTIVE LIGHT?
