IsaacHayes
Didn't put this in flashlight electronics as it's not really for a flashlight..
Trying to do an experiment here with mechanical means instead of solid state this time. I tried wiring a SPDT relay to where it would self oscillate, but it will only latch on, and stay on?!? I'm confused. The sucker should be clicking like a tap dancer who's been up drinking coffee all night...
I wired it like this:
85 Ground
30 Hot +
87a is wired to 86.
So when power is applied to 30, it should engergize the coil as power will go to 87a which is normaly connected and is wired to the other side of the coil. When this happens the point will move away from 87a, thus removing power to the coil, and the process will repeat.
Instead it latches to 87 and stays there..?!?!?!???
85 Ground
30 Hot +
87a is wired to 86.
