kennyj
I managed to find some Krytox grease stocked here:
http://www.aeroconsystems.com/misc/krytox.htm
$9 for a 6 gram syringe of GPL 223 Krytox - General Purpose Grease with Corrosion Inhibitor. The corrosion protection won't really benefit the PD in any meaningful way over the standard Krytox, but it's not going to hurt anything either. In any case, the pricing is good (comparable to Nyogel,) the syringe is enough for PLENTY of flashlights, and the service was quick.
Why Krytox? Well, it's gaining popularity as a flashlight lubricant (along with GLY, the stuff Don puts on the PDs, and the popular Nyogel flashlight lubricant.) Unlike most other lubricants, it's based on Teflon (a popular component here /ubbthreads/images/graemlins/grin.gif) and designed to hold up under a wide range of stresses. It's also very, very smooth.
First warning to anyone considering re-greasing their light: Neither I nor the light manufacturer can or will be held responsible if you screw anything up. If you break it, you get to keep both pieces. /ubbthreads/images/graemlins/poke2.gif
Today I cleaned all the old grease off my PD (been using it on a daily basis for nearly three weeks, since I got it) and carefully applied a moderate amount of Krytox grease. The difference between the new, clean Krytox and the original GLY is mostly subtle, but the reassembled light's overall feel is noticably improved. I'm willing to bet that a large part of the change is simply due to the fact that the GLY was getting "dirty" due to buildup of metal residues from the breaking-in process, but regardless, the piston pushes and releases more easily and smoothly and the head turns a bit more smoothly, though not any easier (not that I can notice, at least.)
I was also able to grease up the O-ring under the bezel (I replaced the lens as well, the standard Arc4-sized UCL lens at flashlightlens.com) I needed to use a dull pin to wedge it out safely, but had little difficulty snapping it back in without letting anything touch the reflector. I wouldn't recommend even attempting this to anyone without very steady hands.
The need for such a task is arguably low (preservation of that O-ring) but then I'm the paranoid type. /ubbthreads/images/graemlins/grin.gif
Note to anyone who attempts this: Do NOT let ANYTHING touch the reflector, the LE, or the inside surface of the lens, regardless of how clean it may be. Once you get the bezel ring off, touch as little as possible and get it back together as fast as you can. You don't want to smudge or scratch up any of the surfaces here, and no, they can't really be cleaned safely.
Anyway, the Krytox seems to do a decent job of staying put in spite of its slippery nature. It still moves itself around pretty well though, so be sure to double-check it after working everything a bit because excess can and will find its way into places you don't want it.
On the whole, it seems there can be some benefit to re-greasing a PD after breaking it in, and Krytox seems to be quite suitable for the task.
