I bought this very light from this very dealer. You can find several comments by me abut G&P bodies and lamp assemblies in the Incandescents forum.
I don't recommend this light, for the following reasons:
- The body gets hotter, faster, than any body I own. If you use it for 20 minutes, it's almost painfully hot to hold.
- The body is not a 3x123A tube; rather, it's a 2x123A tube + 1-cell extender. Nothing wrong with extenders, if done right. But G&P's has an internal ledge that makes it impossible to use AW's 17mm-wide protected cells, be they RCR123A or 17500. The Surefire A19 allows these cells.
- The lens is plastic and can't be replaced.
- The G90 can't accept better heads, such as Surefire's Z44 tactical head or G&P's 43mm miniturbo head.
- The lamp assembly is the older G90, rated at 120 lumens, not the newer one that's rated at 175 lumens.
G&P makes three lines of 123A light: E (bargain), G (midrange), and T (top-of-the-line). I strongly prefer the T lights (T3, T6, T9, T12). They are completely Surefire compatible (tail and head), are better built, and even feel better in the hand. I can't state with authority that they include the 175-lumen lamp, a clickie switch (vs. a twistie), or a glass lens (probably not). But Digilight USA's T9 is built on the G&P T9 platform and includes all these goodies, plus a miniturbo upgrade option, for $75 plus $6 shipping. Add a $20 A19 extender and a $20 Digilight USA 220-lumen lamp and you have a 4x123A light that can use the same miniturbo head. Or add a Surefire A14 extender and three Wolf Eyes 150B (Pila 150S) cells (not AW; they won't work here) and you have a 220-lumen rechargeable.
Another T9-derivative is the Z-3 by LEDWave. See my review under Incandescents. For $55 shipped, you get essentially a rebadged G&P 9S, the miniturbo version of their T9. I've modded it with a Surefire tactical head, Surefire clickie tail, and Surefire extender; I run it on two AW 17670 cells.
In sum: Anyone considering a G&P light should go straight to their T series or the variants sold by Digilight USA or LEDWave. If you plan to extensively mod it, consider instead building a light from scratch using Surefire parts from Lighthound.com.
