LEDSABER said:
Can you mod a Fenix to run on a single CR123 battery? QIII seems good, but I've heard the throw is not great. Can you mod a QIII for better throw?:shrug:
My two QIII have a little bit more throw than my fenix l1p. One of my qIII is a little bit more yellowish than the fenix l1P, but my other qIII is just as white as the fenix l1P. Depends just on the lottery... The throw of qIII is broader, but still a little bit more intense and reaches more far than the fenix l1P. Also, the qIII has smaller but more intense sidespill, which I like more. So for me, qIII has the better quality of light... but it takes 700-800 mA out of an expensive 123-Cell and the fenix takes just a common and cheap AA-Cell... I use recharegeables. My QIII runs with an Li-Ion 650 mAh R123 45 Minutes, the haye to change R123 within minutes. The Fenix runs with an AA-NiMH (2500 mAH Sanyo and ansmann charger) about 2,5 hours and then gives more than an half hour diminishing but useful light. qiii gets very hot with r123 cell, fenix stays cool.
I didn't have made any mods.
For me, the fenix l1p is the more reasonable light, because AA-Cells more available and cheaper. Also fenix is a little bit smaller in diameter. But qIII has wall of light, fenix is just "bright".
So, if You want to use CR123, for me it would be clear to buy a q III, it's even cheaper than a fenix l1p!
Qiii is good quality, looks cooler, but no HAIII-anodizing and plastic lens, holster of fenix is also better than that of the qIII.
