I believe the black 3W light you saw at Sears is the same case as the Sam's Element, I saw those and didn't catch that it was a 3W vs a 1W. I think you may like the Element, though, as it cures most of the Dorcy 1W problems. No blinking mode, and the flutes in the head prevent rolling. The beam is definitely nice, smooth and white, with more flood than most. It does however have the same switch and battery carrier, which means smacking the tail will momentarily break power as the holder negative pulls away from the contact inside due to the battery pack inertia compressing the spring during the whack, and for this switch that means "off" and you have to press the switch to get it back on. That is not as big a concern for me as the light touch of the switch on the side which makes me paranoid about an accidental on, which with the fairly high drain of this bright light will be the demise of the batteries in fairly short order. If I am correct about the model you looked at, all of this Element comment applies to the Dorcy 3xAAA 3W as well. Hope this is usefull input!
