i did it: smalles possible MC-E aspherical
mash.m
Germany
yesterday i had some time to complete my ultrafire wf602c. now it has a mc-e from dx and 13mm aspherical lens from surplusshed.
in original condition it was a seoul p4 with a small reflector and a little boost converter so you have the option of a nimh aaa.
but now to the details: i put out the middle piece so the 602 will be 15mm / 0,59" shorter. the next picture show the middle piece wich is removed now:
after this i put out the converter (i use a aaa lion), glued the aspherical glass lens into the head and glued the mc-e with loctite thermal adhesive.
sorry but i have no pictures from this steps. but if there is any interesst i disasamble the head and make some pictures.
the flashlight looks very used, cause this is my "all day use" light. it is allways on my side and i use it very often.
now i have a very short and small mc-e light with an aspherical lens:
one more picture...
some glow powder with epoxy in the holes.
and now a beamshot. flashlight distance to the wall 4,5 meters / 15 feet, light diameter 1 meter / 3.3 feet complete over all four dies:
the die isn´t 100% focused. but i don´t get it better. there is no space between the mc-e dome and the lens. the back focal lengh is a little to short for the mc-e. but i for me it it ok.
the ligth will draw 1.4 amps from a fresh aaa lion. i know that this isn´t very much for an mc-e, but the efficiency is with this current very high. the light get warm after 30 seconds and hot after 90 seconds. i don´t know the runtime. i used the light often for only some seconds.
markus
:poof: really nice, i like those small monsters ^^ how do u drive the MC-E? 14500 dd?
I pray that you are at least using AW's cells!
we don't want to hear of you blowing off your
b@lls after you run this light for a while, and
then throw it in your pocket! :poof::poof::poof:
But, it is still a neat little build!
Where did you get the aspheric lense?
I actually have a bag of 150 of them in a
20mm size i think:whistle: from USPlastic.
4 c is no problem. i use only protected cells for this flashlight so my balls are safe:p there are some lion cells that are capable of 20c discharge. but i don´t need them. maximun current is 1400mah.
@sabrewolf:
the lens is a glass (not plastic) lens from:
http://www.surplusshed.com/
they have realy good lenses (from time to time) for realy good prices. shipping all over the world - fast and secure.
markus
Very nice mod...how about some outdoor-realworld beamshots? :twothumbs
All the battery and discharge points aside, I really like the build. :twothumbs I'd really like to see/own an aspherical 1xCR123 light but don't know of any on the market. :thinking:
Nice creative build. Consider throwing the cells away after no more than 3 or 4 uses.
4C = certain damage with or without a protection circuit.
Interesting build, it's certainly a winner in the smallest host for a quad-die LED catgory.
I was actually considering trying to buy an old used LF2, then swapping the XR-E in there for an MC-E. But I decided it wasn't really worth it when the light is only driven at 700mA. The amount of lumens I'd expect to lose from self-shadowing would probably offset the efficiency improvement by splitting the current across 4 dice. Although, I didn't consider using an aspheric.
Now, on the otherhand, a single AA MC-E host seems like a potential winner. In that case, a LiIon could safely source closer to 2 amps, rather than only ~700mA.
I'd love to see a custom AA twisty with a 5A or 6A neutral/warm MC-E in there, and a multimode driver. A light like that would be quite the sleeper. On a low setting, it could also be a VERY efficient floodlight producing reasoanbly long runtimes despite the small easily pocketable size.
i used these cell for a long time without any problem. my first build with this 602 was with an cree q5. the current draw was 1000mA. i used the light over 1 jear with only 2 cells. one charge per week. one in the lamp, the other as spare to change when it was emtpy. now use these two cell again with no measurable loss of capacity.
i am driving the cells over the limit. i know what can happen if you handle lions wrong. but i am an electronic engineer, so please trust me - i know what i do.
@all
sorrry, my mistake - no protection...
markus
Hi Markus,
I can't say that I am surprised by your success with discharging 10440 cells at over 2C. Here is a thread from a while back where I was putting forth my thoughts on why this may be safer than discharging larger Li-ion cells at rates exceeding 2C. The gist of my supposition is that the small diameter of the 10440 cell allows them to dissipate heat better than other Li-ion cells and helps prevent thermal runaway that causes :poof:.
Markus,
would some outdoor beamshots be possible???:naughty:
yes of course. please tell me the condtitions you like...
next week i get my new cam, still hope that it will make some better picture. it´s a sony dsc-r1...
but i makke some with my actual cam.
markus
Great! :grin2:
Perhaps it would be useful to compare some lights, with your mod. Also
a longer distance would be nice (10m or more)...;)
