Sold/Expired FS:Warm white/Neutral white Extreme III's.
ARC mania
The land of the rising sun.
I have up for sale 10pcs each of the warm white and 10pcs each of the neutral white Extreme III's. I also have 5pcs in red-orange and 5pcs in red. Each light is thoroughly tested and burned in for an hour before shipping. The Extreme III is a very complicated single AAA powered flashlight that requires a lot of patience. Further details of the Extreme III is as follows:
The Extreme III is a single AAA powered custom light utilizing cutting edge technology. The body is machined from T6061 aluminum, type III hard anodized in natural ( no mis-match ) combined with double side AR coated mineral glass lens, Custom orange peel aluminum reflector, hand selected Rebel LED for optimum brightness and, a micro processor controlled DC/DC converter with multi functions all crammed into a very small package.
The Extreme III is user programmable and the ultimate 1 x AAA powered custom light made in limited numbers.
Main features:
Unique 2 stage output twisting mechanism which does not require the user to cycle through all modes.
Turn Off Memory - the Extreme III will turn on in the last operating mode.
Programmble output for the 2 stage output and 2 stage SOS.
Programmable output and frequency for the 2 stage Strobe.
No flickering at ANY output level as the frequency of the PWM is set at 7800Hz.
Over discharge protection for Li-Ion & NIMH battery. (ON / OFF)
Indicates battery voltage level by number of blinks.
White diffuser for area lighting. (lantern head, container of lube and spare o-rings included.)
The Extreme III is not reverse polarity protected. Make sure when inserting a battery that the polarity is correct.
Specifications:
LED : Rebel LED:
Warm white = LXML-PWW1-0060 - bin number: JNND
Neutral white = LXML-PWN1-0100 - bin number: NSMD
Red orange = LXML-PH01-0050 - bin number: H2B
Red = LXML-PD01-0040 - bin number: G4C
Input voltage : 0.9V - 5.0V (AAA/10440)
AAA battery chemistry : Alkaline(1.5V), NIMH(1.2V), NICD(1.2), Primary Lithium(1.7V) & rechargeable Li-Ion 10440(4.2V)
Uses PWM at high frequency 7800Hz. No flickering from 0.2% to 100% output
AR Coated glass lens (Diameter 12mm, thickness 1mm)
HA III natural finish, no mis-match.
Single o ring seal at lens, LED module & battery tube.
3 positions twisting action for on/off and programming : off, P1, P2
Tighten for off. Reduce the chances of losing the complete head (bezel & LED module)
Lock out mode : loosen 2 turns
Stable tail stand even with small keyring, similar to the KIB flashlight.
Area lighting with white diffuser installed
water resistant
Size:
Length : 77mm
Diameter : 14mm (bezel)
Main functions:
FOUR (4) operating modes:
1. Standard mode - 2 output level. default at 15% brightness & 50% brightness
2. User adjustable mode - default at 50%. Adjustable from 0.2% (8 seconds) to 100% (8 seconds)
3. Strobe mode - 2 stobes level. default 1 Hz at 50% brightness at 15.6 Hz at 100% brightness
4. SOS mode - 2 SOS brightness. default 6.5% & 50%. cycle repeats every 3 seconds
all of the above output and frequencies can be changed by the user via the programming function.
FIVE (5) Extra functions:
1. Battery voltage indicator - works on Alkaline, NIMH & Lithium Ion battery
2. Programming function - User can define the output and frequencies of the 4 operating modes mentioned above
3. Demo function - Will display all available brightness and frequencies of the four operating modes. Demo runs for a few minutes and revert back to previous operating mode
4. Overdischarge protection for rechargeable batteries - works on NIMH & Lithium Ion battery (4.2V, 10440)
5. Factory reset - Restore EEPROM back to factory default settings for all operating modes & extra functions
The Extreme III has a unique design in its software code. It will remember the last operating mode when the light is turned off. the next time the user turns on the light, it will turn on in the last operating mode (i.e. previous mode).
for example, if you use your Extreme III mainly as strobe light or SOS, you do not need to go through the process of selecting strobe or SOS again everytime you turn it on.
This is a limited run. The price of the Extreme III is $125.00 which includes Paypal fees and shipping via express mail (EMS) to anywhere in the world. The Extreme III will ship in batches of ten, in other words, once ten units have sold, they will ship together. I am trying to cut cost by making a single trip to the post office. I can only accept Paypal for payment. When sending payment, make sure to include your full name, CPF NAME, complete shipping address and what you are paying for as well as specify the type of LED. Please send your payment to: arcmania (at) hotmail (dot) com Thank you.
ARC mania
I have one Extreme III with red-orange Rebel LED thats a second. There is a small dent on the bottom of the barrel which is 1mm in length that can hardly be seen. Any takers for $80.00 shipped?
ARC mania
So it looks like you need to sell seven more before you ship the three bought here? Or have you sold some on your site....
Looking foward to this one. :)
:thanks:
The following member's Extreme III's have shipped express:
W8HF - One Extreme III with red Rebel LED
Ed - One Extreme III with warm white Rebel LED
PoliceScannerMan - One Extreme III with warm white Rebel LED
mudman cj - One Extreme III with neutral white Rebel LED
gma - One Extreme III with neutral white Rebel LED and one with red Rebel LED: Sent Black Cat.
ARC mania
Received mine a couple days ago and I got mine on my keychain already.
Beautiful and very smooth N-white(red) beam(both beam tint is nice):thumbsup:
I have a red one and a Neutral white one, and love them both!
Thanks for this very very nice light, and Very Fast Ship:twothumbs
:thumbsup:
My red LED version arrived last night.
Looks and works GREAT!
Thanks!
-Charles
