A Primer on Modern Watch History and Movements.
Bullzeyebill
CA
Thanks for the video. Nothing special here, a quartz movement will be more accurate than any automatic movement, Most of my watches have quartz movements, but non of them satisfy me.
Bill
RTR882
Monocrom, what's your opinion of the Ulysse Nardin Marine Chronometer? I love the looks but don't know much about the quality inside.
Best,
Bob
KITROBASKIN
New Mexico, USA
...but none of them satisfy me.
Bill
Satisfaction with a tool that is so close to you, physically and perhaps mentally, is a great thing, and worth substantial outlay. And the marvel of precision engineering, that too. The issue of paying 5 times or more than it really costs to build is where I question. It is nice to support craftsmen deserving respect, however. And it looks like a hobby with some resale value. Good on all of you so inclined.
The Atomic Solar that I'm using now will have a battery failure at some time, but when? It has already lasted longer than previous watch batteries by a good margin. And where could I get the battery replaced? I have replaced some watch batteries myself in years past.
I was given a basic, Tudor Oyster back in the 70's by my grandparents; Classic, subtle looks. Scratched the acrylic lens but worked well. Wound it every day. Stopped using it when a Seiko Automatic caught my eye. Now that I have a son that may want to inherit it, I pulled it out to check to see if it still worked, but then decided to take it to a Rolex service facility. They wanted to charge a lot of money for a cleaning, etc. but it does work fine. I had them polish the lens, looks nice.
A friend of a friend works on fine watches so I called him. He looked at it and said basically I did not have to have it serviced IF it kept decent time, but what I'm hearing here is that keeping it lubricated is the proper thing to do. It's just that the Rolex people want to take it apart and check and replace worn parts. The resale value for this watch can't really justify it in my mind. What to do?
Monocrom
NYC
Best,
Bob
Honestly, the design of their watches is not my cup of tea. From those collectors I have interacted with, they respect the brand's history and the quality/construction of the UN models. Along with the cal. 118 movement. (Especially the enamel dials of the Marine Chronometers.) Have heard that the 38mm versions wear bigger than they are.
Sorry I couldn't be of more help.
Monocrom
NYC
If it's a family heirloom, chances are it's going to be worth it. (Though obviously not from a purely financial point of view.)
Also, the reason why mechanical watches can last decades upon decades without routine servicing (about once every 5-7 years) is because they're tossed into a drawer and barely if ever worn. Mechanical/automatic watches suffer from a weird characteristic... They can keep accurate time (by mechanical timepiece standards) for decades, while corroding or rusting away on the inside. Until one day, the watch completely gives up the ghost; and either can't be fixed or fixing it would require months of work and thousands of dollars in repair fees.
So, a vintage watch that works and keeps time accurately is a really **** poor indicator of whether or not it needs to be serviced. Any mechanical/automatic watch that hasn't been given a routine servicing for over 7 years, it's going to cost more to properly service it. A decade or two without servicing?... It's going to cost more because chances are that internal parts will need to be replaced. Rolex's price-quote actually might not have been all that outrageous. But before agreeing to pay it, take the vintage Tudor to a skilled and experienced independent watchmaker. (One with experience working on Rolex watches.) Have him open it up in front of you and get a price-quote from him. But yeah, after all these years it's going to cost you to get it properly serviced.
It's actually a typical misconception that mechanical/automatic watches are far more durable than they really are. And yes, they need to be properly oiled. Otherwise you have gears grinding on each other without proper lubrication. Once again, while that's going on, the watch will appear to work perfectly fine; sometimes for many years. But the internals of the movement are slowly destroying themselves.
Another example, a personal one, Dad's old Oldsmobile Cutlass Supreme was over a decade old when he let me borrow and drive it as a younger man. It had an oil leak and needed oil put in about as often as gasoline. So, that's what it did. Car worked fine. Few weeks later, Dad took it back because he needed it. He chewed me out for flooding the engine with oil. So he cleaned out the engine. What I didn't know is, he put in only one quart of oil for the next several weeks. When I borrowed it again, Dad neglected to mention the fact that he stopped putting oil in the engine. Keep in mind he never fixed the leak.
Sure enough, by the time I borrowed it again, the engine had been running on fumes for awhile and was basically bone dry. It was also basically grinding itself apart due to the lack of oil. It stopped at the bottom of the expressway Exit ramp. Yeah, I'll spare you the choice words I had for him after finding out that he hadn't bothered putting anymore oil into it for a few weeks. He knew the engine was bone dry, knew the leak was never fixed, but gave me the keys anyway. Yeah...
Well, for the first hour after I drove it; it seemed fine. Just a bit sluggish, but fine. Then really sluggish. Then dead on the road.
Chances are that's pretty much what's happening inside your vintage Tudor. But at a much slower pace. A car is a mechanical thing, so is a vintage watch with gears and springs inside. Mechanical things need proper and routine lubrication.
Monocrom
NYC
Monocrom:
To my ears your words ring true. Thanks for taking the time to explain this.
Happy to help. There is so much misinformation out there. If I can help out just a handful of fellow CPFers with this topic, then it was worth making. :)
gunga
Vancouver, BC, Canada
The info is great. I did not know about the servicing of mechanical watches (time ranges etc). I'll be sure to keep that in mind.
fridgemagnet
West Cork Ireland
I would really like to know which non-spring drive Seiko movements were the best for accuracy, and which models had those movements.
The only one I know of is the 6159-7001 dive watch, which was supposed to have a very high quality movement.
I have a Citizen eco-drive - Citizen mechanical movements would be of interest too.
bigchelis
Prunedale, CA
Thank you for the Videos and information. Very nice Tissot watch you reffernce too!
I just purchased my first expensive watch ever. A Seiko SBDC007 Shogun Titanium Diver. Not sure why but to me the movement seems adequate but the Titanium and lume of the dials and simplicity of the watch is what made me pull the trigger on paypal.
Best,
bigC
Monocrom
NYC
Happy to help.
The Shogun has definitely developed a cult following among watch enthusiasts/collectors. :)
cw_mi
Monocrom,
Great and very informative write up. Thanks for posting that up. I'm a watch newb for sure. Got into it about three in a half years ago. Started buying up stuff before I really knew what I liked. I tried quartz , manual wind , and auto's. Also started to get into being a "movement" snob. After a while I figured what I really liked and sold off some. Ended up keeping an Omega Seamaster 300 GMT (2234.50) , a Lum Tec M51 , an Olivier Bronze diver, and a generic Italian style homage watch, that actually has a Swiss ETA 6497 movement in it. Paid dearly for that. When it comes down to it now, I wear what I like and don't really care what the movements are. My preferences are autos , but am okay with a manual wind. No quartz for me!
My next watch purchases will be a Panerai, either 510 , 312, or 320 an Omega Planet Ocean (orange bezel) , and if I can find one at a decent price would love a vintage Omega Seamaster DeVille with a black dial , like Don Draper has in the series Mad Men.
