Re: Rant - Rave - Complaint - Feedback - Stress Relieve
Any chance you would consider offering a high output XML-2 Aspheric with the new Wavien/RLT Collar set?
People are waiting almost a year for their new DEFT-X, which in build Quality and Output truly is exceptional with its > 900kcd, but the wait is long and the Price is above the Budget of many.
Saab makes his DEFT-X based on a dedomed XPG2 , mash.m (Markus) makes another model, the Black Bullet-X , with the same dedomed LED :
http://www.candlepowerforums.com/vb...-1-000-000-Lux-Candela&highlight=black+bullet. Both uses the RLT-collar and a 73 or a 78mm asperic lens.
Both Lights are not available/in stock, the wait is probably still long.
The RLT collar/lens is possible to buy directly from Wavien in Kits like these:
http://www.wavien.com/shop/cree/rlt-led-kit/
Buying more collars probably gets the Price down.$ 99 for a set is expensive, but should be cheaper if you buy 10 or more. Perhaps buing only the Collars alone is better, as you probably already have the PCB/LEDs.
Just need to find a nice host with a moddable driver,that can fit this kit/collar/aspheric Lens. I think one of the 3 x 18650 Li-Ion Hosts would be great, for long runtime and a nice UI.
One problem is the Bezel beiing to short. The Aspheric Lens will without a longer bezel be the foremost Part of the Light. Makes it a little vulnerable...
I think a "Vinh54" Model of such a high output aspheric, with an XML-2 driven to 6.5 Amp, on a good heatsink, will be able to sell very well! It would represent something not yet available.
A XM-L2 will give a more usable(wider) beam than the XPG2 Versions, although it may perhaps not exceed the magic 1 Mill Kcd with the XM-L2 Led.
Your good reputation here on this Forum would probably allow the Members here to accept this Light to be prepaid, so there should not be big economical risks involved.
Do you think you could offer something like that?
