I realized that I have not announced the winner yet, the LED thrower of the same size is obviously not in the same league of the HIDs, but I am struggling between who is the winner between FF1 & FF3.
Here is my attempt of trying to use Motor Trend method for cars: scale is 1-10.
1. Performance
Obviously, FF3 Wins, FF3 gets a 10. FF1 get 8. Sure FF3 blow away FF1, but FF1 is 100K & over 2000 lumens, similar to most 35W HIDs, which is plenty bright for most outdoor use. Think of it as SR90 or ebay HID but 1/3 the size, something just as powerful but doesn't need to be a weight lifter to carry it around.
I prefer the beam profile of FF1, has a broad far projection beam but doesn't light up the ground excessively like the FF3. I wish the FF3 came with SMO. the beam of FF1 in SMO is nearly perfect, FF3 has perfect beam with 225 klux, but the light has potential to get over 300 klux with high quality SMO. I felt that they took the easy way out using OP at the expense of throw.
2. Comfort in holding
Both are very lite, The FF1 gets a 10, it's slimmest 35W HID & most comfortable for my hand. FF3 gets a 9, its fatter like the FF2, but very short some how made it
easier to hold, otherwise would have been an 8.
3. Workmanship
FF1 gets a 10. I can't not find anything to nitpick about.
FF3 gets a 9, everything is perfect except the annoying ballast whine. I wonder if commercialization time line is to blame. The FF1 was DIY, where the inventor Shinetop spend countless hours to make it perfect. I don't think he would have let it out the door if the ballast noise was in FF1 like this.
4. Historical significance & value
FF1 is unobtanium. FF3 is commercially available. I would put higher valuation on FF1. FF1 was a revolution. FF3 is more powerful & smaller but it's an evolution. being an evolution & the ballast is obviously 2-mode, I feel that it should have provided user selectable mode, so I could use 24W for most situations & runs cooler, then select 42W show-off mode as needed. FF3 gets a 9, FF1 gets a 10.
5. Run time,
Both about 1hr with panasonic 3100, both get a 9.
FF1 runs cool, FF3 runs hot, to the point I am worried about battery blowing up. I don't think it will, just the feeling you get holding 4 18650 in your hand & the tube it gets burning hot. I must mention that my modified FF3 seem to run a little cooler than the production unit.
FF1 Total: 37 points out of 50.
FF3 Total: 36 points out of 50.
The FF1 won by a hair. The bottom line is, If I had to walk in the woods for an hour in the dark, I am more likely to take FF1 with me instead of FF3. But If I don't have the FF1, I'll take the FF3 which is a better choice for me than just anout any other HIDs.
