don.gwapo
Eneloops are still the best IMO. I got 10 aaa eneloops on my lights and using them everyday for quiet a while now and they never let me down since day one.
Are my NiMh batteries bad on capacity, bad in giving enough current, both, or is this a normal feature?
I would hardly call the Eneloop AAA cell horrible, but they also don't seem to be as robust as their AA sized sibling.
It's been speculated that this is simply a consequence of their significantly smaller size and the fact that some chargers aren't optimized to charge AAA cells. However, since this applies to AAA cells generally, I believe the Eneloop still ends up being the best AAA sized cell as well.
For what it's worth, a set of four I put into service in late 2006 are still going very strong.
When doing a C9000 Refresh and Analyze on AAA eneloops, what charge and discharge rating do you guys use?
Do you use the default ratings?
Thank you.
Thank you very much Ozgeardo! I'm very new to all of this and still ask newbie questions every now and then. Those rates are what I'll use on my AAA'a from now on.I don't think anyone has answered your question yet, however there are some comments that the C9000 is too "robust" on the AAA's :thinking:
Note: the default settings on Refresh and Analyze (1000/500 mAh) I believe are default for typical AA batts not AAA (someone correct me if I am wrong)
FWIW : I have had considerable success using eneloop AAA's and my C9000
For Refresh and Analyze with Eneloop AAA's I charge at 400 mAh and discharge at 200 mAh (roughly 1/3 of that of AA per manufacture instructions if I have calculated them correctly). As I have previously mentioned I use my AAA's in mission critical equipment. They have not let me down yet. I have 5 x 10 day trips coming up in the next 6 months and I will use my Eneloop AAA's charged on my C9000 with every confidence. Any problems and I will be the first to post back on here. (The AAA's I will be using have all been used on 20 plus x 10 day trips over several years).
I am currently keeping a record of all charging cycles and usage of my field batts and hopefully at the end of this year I will have some very detailed results.
I vote Powerex Imedion AAA or Sanyo Eneloop AAA.
You find lots of Newbie 'Questions & Answers' in my Sig Line LINK. Take a look!...I'm very new to all of this and still ask newbie questions every now and then...
For example:...I also like your idea of 'keeping a record of all charging cycles and usage of my field batts' and would like to know how detailed your records are so I can base mine on it...
