TakeTheActive
I disagree.In the break-in mode if you set the cell to 1000mAh, you basically get the same effect for many hours after the cell is fully charged...
In BREAK-IN (800mAh AAA), you're supplying (80mA) 0.1C for 16 hours TIMED. In CHARGE, you're supplying 500mA (actually 450mA if we want to get 'too technical' ) UNTIMED / UNTIL TERMINATION (-DeltaV, MaxV, MaxTemp), then you're supplying an additional 100mA for 2 hours TIMED. If the cells were warm or hot at termination, then you're going to continue heating them, albeit slower, for another 2 hours.
One example of a CPF Archived discussion on this: Maha MH-C9000 Wizard One Charger - Post #42
If YOUR AAA cells don't heat up at 500mA in the C9000 or 640mA in the Sony, that's all well-and-good for YOU. I'm just providing additional information for the reader to make his own 'informed' decision from.
WAY BACK in Post #38 you stated your OPINION:
and in Post #41 I posted mine.For those that aren't doing this, I think you'll have the best luck with AAA's in the C-9000 if you charge them at 500ma, instead of the default 1 amp setting...
