Mike,
Being you're here can you tell us why you carry the AE & not the Brightstar?
John
john2551 said:
Originally AE Light was going to be just a distributor for the BS. However, when they received the BS units they did not meet AE's standard of quality, so AE decided to use their own better quality reflectors. Since then they have made other improvements such as the protective rubber caps. That's why the AE is better and more expensive.lighting1288 said:From the review and picture, they do look the same, most of the spec are the same. I am assuming they are made by the same manufacutre. so, why AE sell for alot more??? :candle:
After re-reading this thread it seems quite apparent to me the Lighting1288 = Kevinchho.
If I'm wrong I apologize but I'm almost never wrong
Mac
Maximus said:I think the AE has an improved reflector and ballast over the Brightstar hence greater light output. Also the AE has a seperate ballast and reflector/bulb. This is a much better design, as if the bulb breaks on the Brightstar you have to replace the whole bulb/reflector/ballast unit !!!
Lando said:This is not actually the case, the bulb and ballast can be separated with the Brightstar by removing 2 small screws at the base of the bulb support. (although I don't recommend you do that unless you really have to because this might void your warranty).
It seems that the AE is brighter then the Brightstar but the trade off is that the AE burns for less then 1 hour, I think I even saw 45 min quoted on the CPF forum somewhere.
Both lights have their strong and weak points, it all depends on what is important to the individual.
Maximus said:Hi all.
I have the brightstar 24 watt and its a very nice light.
However, the claims made by Brightstar for light output are very exagerated.
I would guess mine puts out just over 1000 Lumens.
The run time is exactly as claimed - 135 minutes.
The charging system on the Brightstar IS better than the AE. The Brightstar has a seperate unit between the mains adaptor and flashlight. It looks like the AE Powerlight has the mains adaptor directly charging the flashlight and relying on the li-ion internal battery pack protection to disconnect the charge supply.
Lando said:It seems that the AE is brighter then the Brightstar but the trade off is that the AE burns for less then 1 hour, I think I even saw 45 min quoted on the CPF forum somewhere.
john2551 said:The actual TESTED runtime was 127 minutes: http://candlepowerforums.com/vb/showpost.php?p=1215120&postcount=68
