Got my Stenlight today !!!!! :rock:
I had the pleasure of checking out Dar's before I made the purchase.
But now that I have been able to handle this one all afternoon, I LOVE it.
- I also like the switch, long travel makes it easy to tell what level you are on.
- The size is great, aLOT of light for a light this size.
- Hinge is nice and tight, there are some "plastic" washers that make it not slip.
- Slightly concerned about the switches slot, getting filled with mud.
But you can just wash it out with water anyway, the switch doesnt penitrate the casing. (hall effect)
I decided to make my own battery pack.
I am very firmilar with the 18650 lithium cells used in the Stenlights factory pack.
I used LG 2400 mAh cells, with a 7.2V protection circuit from batteryspace.com
The Triton charger will be taking care of the cells, though I would also like a car adaptor. I may at least get one of the 120V wall wart types from batteryspace.com and plug it into my 12V power inverter.
The protection circuit was shrink wrapped, then the open ends were sealed with epoxy. The cells were also shrink wrapped, but I forgot to take a pic of that :geez:
The clamp shell case is metal, so should provide alot of impact/crush resistance.
It was then epoxy sealed, except for VERY small places by the hinge.
This is was to let gas buildup excape.
I bought a few different metal and plastic blade attachments for the helmet.
But went with the metal one due to its low profile.
I wrapped some electrical tape around the middle of it to make the Stenlights blade fit real tight. Not that it would have fell of if I hadnt.
Please excuse the long bolts sticking out.
Those will be replaced later, I just used them to make sure this is how and where I wanted the bracket.
I will be spending the next few days doing ALOT of testing.
I have a variety of optics and reflectors I want to try in the Stenlight, to get that perfert beam
I might take beamshots using different types also.
I will have a full review of the Stenlight on my site, with better pics,
after a few weeks of hard testing :devil:
First Impression Conclusion? :goodjob: niemidc :rock:
~John
