Part 3 -
Using the most "obvious" battery - the common
1x Alkaline AA -
vs. Stock
Fenix L1T both using 1x Alkaline AA both on High -
not surprisingly (like the NiMH results in Post #
15) - the Cree is noticably brighter than the stock L1T with both on High.
vs. Stock
Fenix L1T both using 1x Alkaline AA both on Low -
even when both are on Low the Cree is still noticably brighter -
this may not be such a good thing - as most people would like a dimmer low.
However, bear in mind this L1/2T circuit was not designed for a Cree XR-E -
and there are two ways of looking at this -
either we get pretty good brightness for about 10 hours of runtime (like the stock version) on low -
or a properly designed circuit would give us a lower output at even longer runtime -
think about the region of
~20 hours for a reasonable low output level like 1/2 this brightness?......
vs.
UWAJ mod L1T both on 1x Alkaline AA both on High -
Remember a U-bin is about as good as a LuxIII can get currently - and the Cree is definitely brighter.
vs.
UWAJ mod L1T both on 1x Alkaline AA both on Low -
Again the Cree even on low is noticably brighter - see comments above for the comparison with the stock on Low.
Control Reference Comparison -
Cree XR-E L1T with 1x Alkaline AA on High vs.
Fenix P1 on primary CR123A
the Cree XR-E even on a humble common 1x AA alkaline is actually about the same - or just brighter than a
Fenix P1 on a primary lithium CR123A - I think this is pretty amazing......
Cree XR-E L1T with 1x Alkaline AA on Low vs.
not surprisingly the Low is not as bright - but even the low seems not that distant from the
since this is the standard L1T circuit - that's about ~10 hours regulated runtime at this level....... so a properly designed circuit could give us hopefully over ~20 hours runtime at a reasonable low level no problems......
Thinking of it with a Cree XR-E to be truly useful one should think in terms of 3 stages - High like as tested, Medium like the current "Low" with about ~10 hours regulated runtime, and a real Low regulated at about 1/2 the brightness with runtime in excess of ~20 hours......
Current Draw readings on 1x Alkaline AA -
Cree XT-E in L1/2T head -
High = 0.80A
Low = 0.22A
stock L1T
High = 0.80A
Low = 0.25A
close enough to be "identical" - so runtimes are probably going to be similar to the stock L1T.
