Those price are so good that I bought and just received 2x 4-pk Ion Core AA.
They're real -
I also bought and just received 2x 4-pk of the Ion-Core AAA. (ordered off eBay Dec/1 @ $10.50 ie: $5.25/4-pk AAA)
Please remember only the Ion-Core AA are reputed to be re-badged Eneloop XX
The Ion-Core AAA are "merely" re-badged regular Eneloops 2nd gen or later.
Again they are real -
Packages:
Marked on the batteries made in Japan:
Embossed codes:
Codes:
32858676HF
40938676Y4
If our best guess so far is the first digital is the year as in 3=2013, 4=2014
and the next 3 digital the day of the year -
it seems one pack is fairly late 2013 and other is 2014.
(Please note: not definitive but merely our best
Guesses)
But the back of the packs were the same:
both were: © 2013.
(this shows that the year on the pack may not truly reflect the year of manufacture of the actual batteries inside -
that is if our assumption of the first digit being the year is right.)
These batteries are being discharged right now to get the initial out-of the pack remaining charge.
I forgot to take the open-circuit voltages but the under-load voltage as initially shown by the charger/analyzers I am using
(@ 200mA discharge) were
#s Initial under-load voltage for discharge @ 200mA)
3-6 - 1.16-1.17V (code: 32858676HF)
7-9 - 1.27V (code: 40938676Y4)
10 - 1.29V (code: 40938676Y4)
Again significant difference between the Maha/PowerEX C9000 (#3-6)
and the Opus BT-C3100 v2.1 (#6-9 - note: no #10 yet, as I only use 3 slots on this charger)
So far:
Initial out of the pack capacity (discharge @ 200mA =~ 0.2C)
# mAh
3 516 }
4 519 } using Maha/PowerEX C9000
5 518 } discharge @ 200mA
6 517 }
7 378 }
8 399 } using Opus BT-C3100 v2.1
9 383 } discharge @ 200mA
10 384}
Note:
#3-6 code: 32858676HF
#7-10 code: 40938676Y4
Notice how much more initial out of pack capacity the first set #3-6 (code: 32858676HF) has over #7-10 (code: 40938676Y4)
In test of my most recent 8x Ion-Core AA in post
#52 above - the Maha/PowerEX C9000 gave slightly lower readings, than the Opus BT-C3100 v2.1 for the same code AA's.
Because of possible difference in readings between my two charger/analyzers -
I've sort of mixed it up for these Ion-Core AAA for the full capacity test -
for Maha/PowerEX C9000 refresh & analyze on #3-5 and #9 (different embossed codes).
intend to use the Test cycle of the Opus on #7,8,10 and #6 for the full capacity.
Update: (note: the text below is pasted from post
#67)
First full capacity test:
# mAh (full Capacity)
3 749 }
4 758 } using Maha/PowerEX C9000 R&A charge 400mA, discharge 200mA
5 753 }
6 767 > using Opus BT-C3100 v2.1 Test mode charge 500mA, discharge 500mA (cannot vary Opus settings)
7 836 }
8 902 } using Opus BT-C3100 v2.1 Test mode charge 500mA, discharge 500mA (cannot vary Opus settings)
10 825 }
9* 829 > using Maha/PowerEX C9000 R&A charge 400mA, discharge 200mA
It seems the second set #7-10 (code: 40938676Y4) measures noticeably higher full capacity than the first set #3-6 (code: 32858676HF)
Set #3-6 (code: 32858676HF) results are a bit lower but seems to be in line with my very first 2 Ion-Core AAA (code: 30518676AN) (see post
#1)
SPECULATION: (Please note: this is not anything definitive)
Based on the assumption the embossed codes have some relation with date of production
(best guess: the first digit is the year as in 3=2013, 4=2014;
the next 3 digits may be the day in the year.)
So my first 2 AAA -
#1-2 (code: 30518676AN) were 2013, day 51
these most recent 2x 4-pks:
#3-6 (code: 32858676HF) are 2013, day 285
#7-10 (code: 40938676Y4) are 2014, day 093
It would seem that the later production for Ion-Core AAA marked 4093 come pre-charged with less than 50% of their full capacity
BUT they seem to have noticeably higher full capacity than those marked 3285 under test.
Therefore my speculation is from about the start of code 40... Ion-Core AAA may have changed to a different/later(?) generation of standard Eneloop AAA
Of course all this is based on very limited sample of 10 Ion-Core AAA.
But anyone else with Ion-Core AAA please check the embossed codes and see if codes starting with 40 and later are actually like mine?
Thanks,
