I also bought and just received 2x 4-pk of the Ion-Core AAA. (ordered off eBay Dec/1 @ $10.50 ie: $5.25/4-pk AAA)
Please remember only the Ion-Core AA are reputed to be re-badged Eneloop XX
The Ion-Core AAA are "merely" re-badged regular Eneloops 2nd gen or later.
Again they are real -
Initial out of the pack capacity (discharge @ 200mA =~ 0.2C)
# mAh
3 516 }
4 519 } using Maha/PowerEX C9000
5 518 } discharge @ 200mA
6 517 }
7 378 }
8 399 } using Opus BT-C3100 v2.1
9 383 } discharge @ 200mA
10 384}
Note:
#3-6 code: 32858676HF
#7-10 code: 40938676Y4
Notice how much more initial out of pack capacity the first set #3-6 (code: 32858676HF) has over #7-10 (code: 40938676Y4)
In test of my most recent 8x Ion-Core AA in post
#52 above - the Maha/PowerEX C9000 gave slightly lower readings, than the Opus BT-C3100 v2.1 for the same code AA's.
Because of possible difference in readings between my two charger/analyzers -
I've sort of mixed it up for these Ion-Core AAA for the full capacity test -
for Maha/PowerEX C9000 refresh & analyze on #3-5 and #9 (different embossed codes).
intend to use the Test cycle of the Opus on #7,8,10 and #6 for the full capacity.
I will return to update the results as they become available.
