StandardBattery
Bezel Up? :thumbsdow:thumbsdowWhy doesn't the Moddoo Clip work for Bezel up carry with the Rotary?
Well, according to Henry, expected to appear by end of this month but it would be in very short supply.
I hope demand completely outstrips supply. If high CRI runs sell out quickly, perhaps other makers will take notice and we'll start seeing high CRI as a more common option.
--flatline
--flatline
I believe some already have. Malkoff and Army Tek come to mind in the non-custom arena and from all accounts Gene's drop-in has a beautiful beam.
And so is Zebralight.
going off topic here but please be aware that the zebralight high CRIs are featuring LEDs rated at 85 CRI. that's not such a big difference compared to standard LEDs.
Probably won't happen. The vast majority of flashlight purchasers, even knowledgeable enthusiasts like the folks who hang out at CPF, are more impressed with a big number on the box than they are with the quality of light coming out the front.
Still, it's good to hear that the high CRI lights are finally in production. Hopefully when they're listed they won't sell out before I can get my order in.
For those who might still be on the fence, Over Ready has their remaining ceracoated HDS 170T's for $182.00.
Mine actually came like this. I'm not sure if they're all caused by the same problem, but here's what I did to fix mine- remove the switch cap and flip it over... you'll see where to tighten the rubber tail cap... just tighten it and your problem will be fixed. You can use a lot of things to tighten it, but I found an old chisel worked GREAT since it was perfectly wide enough (just be careful). The more you tighten it the more 'play' the rubber cap will have before clicking. Here's a picture.
I suspect the problem here is that the light is so close to the wall. That is not your typical beamshot.
Proflash, could you post a shot from 6 feet away?
I did a test with all of my lights and they all look crazy so close to the wall. Also the camera exposes differently because of super-bright hotspot.
Read through here if you need a reference.
Thanks TyJo, didn't see that.
I modded a 200 to neutral for a CPFer and didn't notice the ring, I'll check with him tomorrow and have him inspect it.
If not, this one may need to head back to Henry, maybe a mismatched reflector has it sitting high.
ProFlash,
The stop shoulder on the reflector should prevent any focus issues with the reflector,
Does the shoulder fit flush to the head?
Have you installed a bezel-up clip on the head?
To support the reflector theory I offer a pic of my EDC 120 XM-L with the reflector unscrewed just barely.
Unscrewed
Screwed in
Please note that I'm running an unsupported emitter in this so the "screwed in" pic may not be as smooth as a stock emitter.
I don't see much, if any, of a gap between the knurled section and the smooth shoulder on the reflector.It does appear that the reflector could be sitting high. I'm guessing that it needs to be tightened, but I can't seem to screw it in any further. Is there a special way to tighten the reflector without touching the inside?
Judging from what I've read, the beam on my light is not what should be expected from an HDS. I think I'll contact Henry tomorrow and see if he can help; I really don't want to part with my HDS though :sigh:.
