bigalex310
- Joined
- Dec 27, 2011
- Messages
- 8
I have a cheap spotlight from tractor supply that I decided to upgrade to a higher wattage bulb. Well, while I was playing with it I let the positive and negative ends from the switch circuit touch sooo I believe I fried the entire switch and charging circuit. The batteries and the new bulb are fine so now I need help figuring out the easiest way to be able to charge the two 6v lead acid batteries in the spotlight. Any suggestions on this issue?
Any help would be greatly appreciative, thanks in advance.
