Jason 77, your schematic looks fine EXCEPT - (1) I would get rid of the .001 capacitor at the sense resistor, and (2) check the voltage at the positive input of the comparator with the potentiometer set to max. .05 volts gives you 1.0 amp. I get .045 volts there at 850ma, for example. Also, I sent you a private message, not sure you check your forum messages... Jeff
Ok I rebuilt the circuit using a fresh LM393 and took out the .001uF as you suggested. I actually went down and bought a 10kohm linear pot from frys as I wasn't 100% sure the ones I have are linear. The circuit now works fine I think, I can touch the pot and the heat sink for the mosfet and there is no change in the light output. I took some measurements and found that when the voltage at the positive input of the comparator is .05 volts the circuit is suppling the LED with 800mA of power, however at full tilt "pot up all the way" I get .074 volts and the LED is getting 1.24 Amps... The .05 ohm sense resistor is rated at 1% tolerance but when I measure it with my multimeter "fluke" I get .03 ohms, although I am not sure how accurate the meter is when measuring resistance under 1 ohm....
The high-CRI light remains unmodified. But I have made a new light that helps to fill-in with my photo lighting setup, Hydra-3. It is a non-high CRI neutral white Rebel-ES 1000-lumen flashlight and 2,000 lumen floodlight. It does have a light-stand fitting like the high-CRI light:
Jeff O.
I am curious as to which Rebel ES LEDs you are using as the highest neutrals I have seen are rated at 310 lumens at 1 amp?
Yes I do realize that thanks for the hint though...Jason 77, if you haven't given up, allow me a silly question. You do realize that you have to supply ground and V+ to the comparator, right? These connections are not shown in the schematics reproduced in this thread.
