JimmyM
Solution to reduce sleep mode power drain.
Very early in our design discussion we lamented the parasitic loss created by the sampling divider. We came to the conclusion that is was small enough to forget about. But I wanted to solve that problem.
Some quick math:
For Vref: 1.1V
Vbat 40V
Sample divider: 360K & 10K
That leaves us with 0.108 mA drain
For Vref: 2.56V
Vbat 40V
Sample divider: 150K & 10K
That leaves us with 0.25 mA drain
That might seem quite small, but it's pretty large compared to the AVR sleep mode current of ~0.0006 mA.
So I had an epiphany. I've been working with some small FETs with a Gate Threshold of just 1.8V.
If a small N-FET is placed between the Upper resistor of the divider and the ADC input, it will isolate the ADC and disconnect the sampling divider current path. Since the AVR is driving the gate with 5V and the drain leg is, at most 1.1 or 2.56V above ground, that leaves us with 3.9-2.49V between the Drain and Gate. Well above the 1.8V Gate threshold. I tested this last night and it works great.
Sampling divider parasitic losses can be reduced to the leakage current of the FET. In the case of the one I used, <1 uA (0.0001 mA). The added component is an addition to complexity, but since these can be had in tiny SC-70 packages, the impact on space is very small.
Some quick math:
For Vref: 1.1V
Vbat 40V
For Vref: 2.56V
Vbat 40V
