Lumens is not meaningful without beam shape info.
For example, 100 L focused tightly is plenty of light close up on a small target of interest, but woefully inadequate on a large distant target.
Example, I have a 131 Lumen Maglite 3 D LED that can throw ~ 3-400 yards. The beam will illuminate a small circle at that range, but, will leave my feet in the dark, and be worthless to use to walk with. If I aim the little circle of light down at my feet, its too tightly focused to give a useful flood, and there's little useful light to see a path/avoid roots, etc.
If I use a Zebralight SC600 it has a broad pool of light, and is excellent for lighting a path for a walk, etc....but its worthless to see any detail over ~ 60 yards away, etc.
IE: A lot of lumens, spread out over a large area, results in a small lux result...so you see a wider area, but dimly, compared to a the same lumens concentrated into a tight beam...so you see only a little patch of light, but with a higher Lux value.
For most tasks, I'd rather light up a wider area and see more context for my environment. If we agree that we see best in daylight...I think its silly to pretend that less light than that is good. Ideally, it would look like we were in day light if we had to see something.
Anything less than that is a compromise in vision.
As making everything around us lit up as if it were daylight is not typically practical, we compromise and talk about what we can get away with, not about what is truly ideal.
To that end, if you think about the OP...the better question is how many LUX is enough for each task....not lumens. That will account for the beam distribution...as its applicable to the scenario...if you need to see a small or large area, it doesn't matter...as WHY you need to see it, for what purpose, will typically dictate how well lit you need it to be, and the value that describes that is Lux, better than lumens.
To simplfy things further, as guidelines, there are published standards for the Lux recommended for many tasks, including emergency egress lighting, crawlspaces, and a great number of occupational and residential tasks.
