Gunner12
I see, some new info that I didn't know(about schools in Canada).
The RC-F4 with RCR123s is just at the edge, I wouldn't recommend it.
17670 batteries are about the same size as 2 CR123s stacked on top of each other. 17670 batteries are 17mm wide and 67 m long. A Cr123 battery is 16mm wide, and around 34mm long. Similarly, a 18650 battery is 18mm wide and 65mm long, though some should be labeled 18670. The protection circuit adds some length.
A 17670 battery has a bit more capacity then 2 RCR123s and 18650 batteries have more capacity then 17670 batteries.
According to this runtime graph(from this thread) the RC-N3 runs a bit over an hour on 1 RCR123. Here's runtime on 2 2300 mAh NiMh AA batteries.
By eye the RC-F4 should be around 30-40% brighter then the RC-N3 on 2 AA batteries. The difference between the RC-N3 on RCR123s and the RC-F4 won't be that much 5-10% by eye at most. Our eyes sense light logarithmically, as in it takes 4x the light for one light to seem 2x as bright as another. You might see a difference but it won't be a great difference.
