mateen said:Could one of the empty slots be custom configured to give:
Low 100mA - High 750mA - Strobe 750mA - (nothing) - set UI?
Rippey said:Finally got mine, Canadian to Texas postage is slow. :thumbsdow
This thing is pretty cool, I put it into a Q3 pretty easily. Now the hard part is figuring out which mode I like best and which brightness levels to set it at.
Rippey said:You sent it the 2nd, and I got it today (the 13th). Only 11 days, sure felt longer than that
Should note that the board seen in this post is not the board(pcb) you get. It is a very well made board, see his other posts for the real board.
The TWOJ doesn't look any better than the SX1K that came in it, though. Luxeon lottery I guess. I bought my son a 1W light from Sam's Club, it looks brighter and better than either of these 3W's and it is a QX1, go figure.
Still playing with this board, it sure does make the light do some neat tricks. Only change I would make is to put Max into mode 3 like mode 4 has it. Then have it where it would remember what it used last (either user low, user high, max, strobe, etc.)
Have to get back to playing with it, going to change the strobe frequency next...
goldserve said:I would keep the remembering of modes in mind if I make a new revision of firmware.
I hope you are using rechargable 123s. If you aren't, WHAT ARE YOU WAITING FOR? You will not get the full potential from the TWOJ if you don't use R123s. AW sells protected cells and a charger for less than $15. One or two cells is all that is needed.
