Just come in from shining the x65vn, 10,500lm and 600kcd+ outside with the boss. She loves it, loves the 5000k " like daylight" beam...............So i enjoy my lumens and nothing will change there. However, this weeks flavour of the month kicks out a whopping 320lm max in 5000k luxeon T flavour. The light is the sc62d, really enjoying it on the H2 setting(H1 is 320, H2 is 145lm iirc) for a do it all output. It ended up in my jacket this morning(you know those subconscious things you do, already having another ZL in my inside pocket). So i used it today as my work light on the compressors.
Quite a few of my light i can program, one is in the body of a z2 and has a quad 218b 4000k with the h17f driver(dr jones). This has many options, 2 mode groups of up to 7 levels each, all pre set to what level you want out of 24!. I simply have it set to a 1 mode, guess around 300lm ish for again, a do it all level(i like simplicity..............).
As mentioned, the driver made by Tom and tweaked by toykeeper is today one of the best imho. Ramping UI, instant low/high and pre-set 350ma level(works out around 140 useful lumens). Bat check for voltage readout, parameter settings for driver temp..............goes on inc tactical mode which is like a max/momentary(press hold for light, release and it goes off).
So even today with crazy 30s outputs, some can be tweaked or used with ease at more sustainable levels without burning retinas or anything within 100ft. Yes output gives me
all this time on, but when its time to use for specific applications, i can dial in the output required. This is anywhere between 25 and 300lm in general, most uses i would put between 100 -200lm. Having 1 or 2 lights myself
its still hard to (ok impossible) to have 1 light that works for all my applications. So i have several, different fuels(from 10180 to 26650), different forms, different colour temps and tints. Different LED's, beams be it orange peel,smooth reflectors ,optics be it clear, narrow and frosted etc etc. Then UI, be it rotary,infinite, side switch, rear forward,reverse clicky, multi mode along with single..............you get the picture. Lots of variety which is not always the most user friendly way to go, but keeps my interest constant.
Variety is the spice of light!
