NewBie
*Retired*
Re: Is the $250 price for the Arc 5 too expensive?
In this price range, 150-350.00 I'd like to see something with an enhanced aluminum coated reflector with thin oxide overcoat (the type that doesn't degrade the performance) or even the same in an enhanced silver. Not some machined aluminum that has a urethane overcoat with dust and other goobers in the urethane.
Ribs or groves in the reflector, although only cosmetic, are also taboo.
I'd also expect a UCL type lens, a two side AR coated glass, or two side anti-reflective coated with hardcoat Acrylic.
I'd expect gold or silver on all electrical contacts.
I'd expect flawless operation in all aspects.
Any custom grinding to make bad parts fit would need to be done in such a matter that I don't notice it.
Dropping it better not break it, even on concrete. I'd prefer something such as rubber baby bumpers such that the finish is not damaged when dropped on a flat surface.
I'd expect a uniform and flawless coating on the body, where the pieces actually match each other exactly for color, with no pits or pinholes.
I'd expect not to find evidence of manufacturing, such as dust, dirt, hair, lint, etc.
If it utilizes a converter (like a boost or buck), expect efficiencies in the +90% range. If it was a buck-boost or sepic, I'd expect near 90% efficiency.
I'd expect no farkle of the emitter.
Yeah, I'm a tough customer, but only because I have a little tiny bit of knowledge.
There is a reason custom lights cost so much, they are not being made in volume, only a few hundred or less. When you get into volume, parts cost and production costs go down, the economy of scale.
