Hi SilverFox,
Thank you for the reply.
It is strange that the melting down happens even when charging current is 200ma.
In worst case, about 2V X 0.2A =0.4W heat will be generated in the battery,
supposing no energy is transferred into chemical one. I don't think such heat
will cause the melting down. It might be the malfunctioning of the CPU there or
the chemical reaction inside the battery.
I think the shutdown temperature could be changed by changing the resistors near
one of the holes where the thermal sensor is mounted. They are two 7.500K
precision resistors in parallel, 3.750K equivalent. Since the thermal sensor is
measured about 9K @70F, a 6K resistor will change the shutdown temperature to
about 120F, I think. Need to be confirmed by experiment.
So keep an eye on those 2500mah batteries and above when they are being charged.
I'll order another one as backup in case melting down happens on me.
