Hi jtr1962,
You are welcome!
The resistance of the thermistors in my BC-900 is measured only about 9.2K at 70F. 12.2K is about 30% above the 9.2K. This might be another factor causing the melting down.
I also checked the waveform around the thermistors. It seems it measures the time charging a capacitor (near the hole) from 0V to about 1.2V through each of the thermistors or the reference resistor to check if the temperature is higher than the reference.
I also noticed that there will be a gap between the metal plate and the battery if it is not well installed. This would make the charger think the temperature there lower than real one.
You are welcome!
