flashlight nut
Rotating the tailcap does not require two hands. This function is easily accomplished with the thumb and index finger of the hand holding the light.
This depends on the light, Most of the current multi mode models use the head as the switch.
Maelstrom 5 & 7
O light M21X
Eagletac T20C2 MKII
I know there are many more
The Fenix TK-21 and O light M20-S have a secondary button, but side switches are sometimes (almost always) in the wrong position when needed. Those who use a Magcharger or Streamlight SL-20 probably end up rotating the light around to orient the switch often
I whole heartedly agree with you about fine motor skills. The problem is determining which motor skills and thought processes are most important. Try performing simple drills at the range such as moving and shooting with short burst of light. Then throw in reloads and clearing malfunctions. While using a soft press to momentarily turn on the flashlight, most people will inadvertently press too hard and activate constant on. Now their attention is directed to the function of the light and not on the threat. In a high stress situation something so simple can have dire consequences. If this happens during a reload or while clearing a malfunction, the officer is lit up so the bad guy knows what is happening.
Both arguments are valid and no one light will perform best in all scenarios. All I ask is that you train with your equipment and make sure it performs the way you expect it to.
Hey Cap, what's the tailcap on your light? I recognize those Modoolar parts, but I must have missed that tailcap. I love the way it all comes together!
Now i just thought about this. If i am correct, the Klarus XT11, if i may speak boldly, has all light powering buttons at the tail end of the light (making it easily accessable) with no recess to guard or protect from an accidental activation. in covert operations and traversing slow movements to gain a position, this could potentially give a well staked position away in the event of the light turning on. I now know why Olight did not change the side switch of the M20S to the newer prototype switch that was slightly more raised . Its recessed for a reason, but still there just the same without complication or after thought. Just strategically placed and recessed enough away from initial contact of hand. The back any light is considered a protrusion. with enough prolonged shock, movement or accidental falls or drops, it will turn on without the users consent. This cannot happen in "STEALTH MODE".
