[ QUOTE ]
jtr1962 said:
I don't doubt HarryN's credentials. I'm just saying that this is the first I've heard of this difference in lifetime between different LED suppliers. And how does one know which chips end up in the LEDs you buy anyhow? For all I know the cheap HK LEDs may be using chips from Cree or Nichia. I'm planning on doing some long term testing of the various colors I have. I already know UV dims by quite a bit even after a few hundred hours, but this is a problem common to all UV LEDs as far as I know, or else they would be used in white LEDs instead of blue. Anyway, I'm finding this all very disturbing, especially if the LEDs in traffic lights don't last the claimed 100,000 hours.
[/ QUOTE ]
Dunno who HK companies are utilizing. Some Asian LED makers are in fact using CREE die, as well as Toyoda Gosei, the CREE die are distributed and rep'd by Sumitomo, the last purchase was for 160,000,000.00 dollars of LED die (the tiny chip inside the LED). There are quite a number of island based die makers too though....
In fact, Toyoda Gosei has even made die for LumiLEDs.
Some of the big factors in LED life in recent years will be in the packaging. Die attach adhesive, and how well it resists light (especially UV) (some are actually soldering down the die themselves, where Luxeons have a die that is floating on I think it was 16 solder balls that rest on a ESD or Zener diode, dunno if they solder their zener to the heatsink though, unlike others who do), in whites, the life of the phosphor (phosphors also have a lifetime), the filler material often used to make the body from (as in 5mm)- as most by know know the epoxy yellows with time/temperature/light exposure, some fill with versions of non-yellowing silicon (for example, GE's X-14 LED silicone) (such as newer Nichia's, CREE XLamps, LumiLEDs Luxeon, and OSRAM's Dragon) some have an acrylic dome (seems those'd yellow too with time) to cover the silicon gel, others use no dome, or even a glass lens. Additionally, you'll find some even in a metal can with a glass lens, and Microsemi was pursuing a metal leaded, and all glass package (no goop, gunk, plastic).
I've querried Toyoda Gosei (who makes a LED with a UV die and RGB phosphor, which doesn't rapidly degrade like everyone said it would), Nichia, and CREE, none of them have ever heard of the UV attacking the DIE itself, unsure where that rumor came from.
In fact, you'll find 20,000 hour UV LEDs here:
20,000 hour UV LEDs
Oh, there is a huge difference between LED suppliers, as they utilize different packaging, and I have some white LEDs from an asian source that keeled over an barely glow anymore, even ran within their specs. The quality of the die itself, can't tell you much about that.
The reason blue is used instead of UV is the YAG phosphor is matched for the blue. The folks like Toyoda Gosei, who have been making a UV based White LED utilize a special version of RGB phosphor. The color rendering is much higher than the blue die-yellow phophor, and pictures taken where those are utilized as a light source look *much* more natural.
You can read more here:
http://www.microlamps-tg.com/
http://www.microlamps-tg.com/html/Prod_white_compare.htm
Datasheet:
True White Hi
Catalog:
http://www.microlamps-tg.com/html/Cat04_01.htm
As far as the 100,000 hours, alot of it has to do with the skill and experience of the companies that designed the traffic light. This is one area where buying from the cheapest bidder can result some very unhappy campers. It's these companies that will give LEDs a bad rap. Just like the millions of CFL bulbs made by GE and Sylvannia that were only lasting a few months for many folks (yeah, other brands had the issue, but those two companies really showed how incompentent they have become).
You can even underdrive the LEDs and use more of them, to extend their lifetime....been there, done that.
