"Mini Tag" Keychain/Neck Light with Builtin Recharging
Matt7337
Northern Ireland
This looks very interesting! I might actually go for one of these, but would like to see that "Gen2" prototype first of all :)
Sabrewolf
Ambler P.A.
I still have some more work to do :thinking: And i thought i would have 4 proto's
out by this past weekend.. But fate was not in the cards for me :mecry:
The back of the Gen2 needs some machining, And will end up a bit rounded
on the backside where the lanyard/chain hole goes through. It also has
alot of glowpowder mixed in with the epoxy too. The magnet charging
setup has been revised, But may change to something smaller in the
full production version. Also, I will have a Green G10 Proto made for all to see.
But here are the pics of the Gen2 with recessed led's sitting next to the Gen1 :twothumbs
I also have to round off the corners and make the cover match the body 100% just like the Gen1
The Pre-Pay will be starting This Week! So you can all jump in on the party :eek:
Sabrewolf
Ambler P.A.
Corners Rounded :cool: The lanyard hole is next (goes on the side opposite the leds)
Whatcha thinks folks?
dom
Australia Geelong
Looking good Sabrewolf.
You are losing a bit of illumination by the looks of it
with the recessed LEDs.
You'll sell your proto one with the LEDs sticking out to me ? :)
Cheers
Dom
Sabrewolf
Ambler P.A.
Cheers
Dom
Actually, The Gen2 Proto is only about 1/3 charged :grin2:
So it would be much brighter than in that beamshot.
Ohh, And Yes, I would sell ya the Gen1 :cool:
dom
Australia Geelong
Excellent.Look forward to a side by side charged up pic.
The charging contacts on the Gen2 look great.
What do the units weigh?
Cheers
Dom
scout24
Penn's Woods
:twothumbs Looks great! Paypal loaded and ready... Love the recessed design as well as the charging!!! PM Sent...
JakeGMCHD
WI
I like the rounded one with the recessed lights best. Could be interested in a couple of them. Depending on output and final design.
Sabrewolf
Ambler P.A.
The final shape won't change except the length.
It will end up being a little longer than the Gen1,
Including the Led's. So the new dimensions will be..
2.25in x 1in x 0.330in Or 32mm x 25mm x 8.5mm
Here is the lanyard hole all drilled out and " Hangin' "
Morelite
Central PA
I know you are offering CF or G10 cover plates but is there an option for Ti plates like on the Mini Chimera?
I see 3 magnetic contacts for charging, why 3 may I ask?
Sabrewolf
Ambler P.A.
Its possible that i could do Ti. But i have no provisions in the design
for screw holes to hold the cover on. And it would certainly make the
light heavier. I would estimate it ending up at 2oz with Ti covers :eek:.
And the machining costs would be a little but higher. It can be done :thumbsup:
The 3 magnets are setup as 2x negative (outside ones) and a positive center.
It's setup to be flipped around on the charging cable without shorting
out the connections.
Sabrewolf
Ambler P.A.
Is the carbon fiber thick enough to accomodate a trit?
I could do trits in the covers.. but certain locations wouldn't work.
Like on top/below the battery. Being that the battery is the
same thickness as the center section, and the covers are not thick
enough to allow installing a tritium.. I would have to install them around
the power button or on the metal casing itself.
karlthev
Pennsylvania
Well, back home again..whew! Nice light, real nice light! Now....where does the Pay Pal thread start.....??? I'm in for one...!!
Karl
