StevieRay
Well, I was able to get the cap off with a strap wrench. Came off very easily.
What are those two little wires for inside the cap?
StevieRay said:Well, I was able to get the cap off with a strap wrench. Came off very easily.
Whitelitee said:Do you push it out through the top or the battery cap end?
Which other one did you remove? I don't see another one marked A475?Whitelitee said:Damn I removed the wrong one
FNinjaP90 said:150mw? Be careful, too much power can burn out the diode. Then.....$200 down the drain. But if you want the be the guinea pig to test the laser's limits...be my guest.
