Okay. Updates. I got my 2x tiara pro today. 11 days, decent since I ordered on Christmas day.
Tiara pro c1, high cri xml2
Tiara pro a1, warm xpl
Coincidentally I picked up a lightly used tiara pro a1, high cri xml2 yesterday from a local fellow.
While these are all v2 models, the ones from Armytek have yellow buttons and follow the manual (with two turbo modes). The local a1 has a white button, a single turbo mode and small differences in the programming interface. Annoying.
I thought I would get annoyed by the pro UI because I didn't want to learn yet another complicated light (I have lots). In the end, the extra flexibility of the pro model (especially access to moonlight when on) was appreciated and easy to master.
The flashing green state indicator is annoying. I wish I could properly shut it off. I used the control sequence in the manual and did a lot of research. No dice. On regular and turbo modes, it always flashes every 5 seconds. On moonlight, it flashes 2-3 times (Armytek direct lights) or 4-5 times (tiara bought locally) then stops. This is annoying but acceptable.I have not managed to change the behaviour of this in any way using any of the Armytek methods I've seen.
Overall the UI is quite good. I just wish I could shut off the green flashing. I also wish they were more consistent. When it is used as a headlamp, you will not really notice the flashing, but I like to use them as handheld lights, flashing is distracting and may wake the kids (it's way brighter than the moonlight mode).
Level selection is good, with nice spacing. Moonlight is a touch brighter than the crazy dim I like, but is good.
The finish is a bit chalky. Grippy, seems durable, picks up grease and dust like mad. Unique.
The lights are HUGE. The Tiara A1 (AA light) is the same size as my Zebralight H600fc iii (18650 light) except the battery tube is skinnier on the Armytek. It's comical. I know it's done to same on manufacturing costs but it's still way too big. The C1 is still big but at least it seems more justified and it fits 18350 batteries. That is cool.
The construction seems solid. I've heard of a lot of issues, especially after light usage. Hopefully I don't succumb to this.
Beam is a nice punchy flood as has been described before. my favourite beam pattern.
Tint. This is where things get interesting. The XPL "warm" is around 3800-4000K estimated. It is quite pleasant with a very mild green/yellow tinge. It's hard to really notice unless you look for it. Overall, one of the nicest XPL neutrals I have seen. The only issue is that I'm spoiled by Nichia 219A/B/C, 5D1 XML2, XML2 Easywhite etc. The green is much more noticeable when compared to some of these beautiful LEDs. Again, it's one of the niceest XPL neutral I've seen (most have been so gross and green I've modded everything to Nichia). So, by itself, it's great, but it doesn't rival a Nichia.
The high CRI XML2 is interesting. Very warm (2800-3000K) , with an orange colour cast. Very much incan like. Looks a bit dimmer than it is due to the colour. Overall, very cozy tint. Like a candle. So while it's high CRI, everything looks tinted, like an incan light. It's not for all applications, but is unique, cozy, and comfortable. Great for late at night, relaxing times. Good outdoors too.
So, all in all, I like all of them. Not perfect, not compact, but unique and usable. Nothing super annoying (except the blinking button). I know the non-pro models don't blink but I like the UI flexibility of the pro.
Overall, I'm undecided. I may return one or both of the headlamps I got from Armytek. Can't return the locally bought one but it's pretty nice. Just not sure I can justify all these, and I might just want the next gen Zebralight instead.
