glockboy
Then use the clothes hanger wire with bubble gum at the tip.
I can see part of the missing light through the seems.
Clothes hanger just gets stuck. Shark Vacuum was a fail.Then use the clothes hanger wire with bubble gum at the tip.
Hose-magnet is an interesting idea, and I see some sort of clasping snakes on Amazon, but I'm not spending $30 to retrieve a $30 light unless the NiMH eneloop is a fire hazard back there.
Annoyingly, if she had put it down one of the lower two tubes, I could easily retrieve it from the bottom grill which is removable, but the upper two tubes have an iron plate at the bottom. [emoji30]
Green arrow is the tube it's stuck down, red arrow is the seam thru which I can see the split ring
Tried with a clothes hanger wire, just gets stuck. It's a very thin vent tube, unfortunately.Wait... It has a split ring attached? Why not taking a metal wire, make a hook on its tip and "fish out" the light?
Thank you. This bit is the rub. We moved recently, that radiator was at a house owned by a relative and I still do need to figure this out before winter. I believe it is a steam system, the radiators in the rest of the house are the type with those circular vent valves with +/- on them.Not sure if you resolved yet. I did HVAC for 20+ years...
I dont know what happens to an eneloop under heat.
I emailed Panasonic, but I suspect for liability's sake they'll tell me to pay to have it removed.Lots of NiMH MSDS info available with a websearch ....
This should work; NiMH batteries contain enough ferrous (or at least magnetic) material to be attracted to a strong magnet even through a flashlight body. A good source for high-strength neodymium magnets is United Nuclear Supply. (Don't worry, the shipping label says UNS, not United Nuclear... the USPS won't be afraid to deliver your package.) I would use a wiring fish rod with the hose, to make sure I could get the magnet to the nearly-departed Fenix. (After all, you can't push a rope, as the saying goes.)One other alternative which could possibly work is stick a magnet inside a hose with a string on it so you can lower it to the light and use the hose to keep it from sticking to the radiator.
There are flexible "claw" devices sold at most auto parts stores for less than $10. The flexible shaft gets close to the light, open claw, advance, close claw.pull the light out. You can buy a flexible camera to guid you if needed(less than $20 from China, Harbor Freight sells them too, more expensive though).
