roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
Anyway, you can;t satisfy everyone's need in a sole product.
That's true, you should just choose the light which works for you.
Thanks for the suggestion, but unfortunately there are more specifics for my ideal light - neutral white tint, revert to low mode not high when off, etc. I already have several lights that I like, but none of them are my ideal light with the specs I mentioned above. I haven't found it yet...I can place my ohter fingers on the sidebutton to change the mode while my thumb on the tailswitch .
Maybe bfksc you could still consider this one after someone review it.
Unless size is critical, out of the PD22 and LD22, I'd personally go for the LD22: better runtimes and uses AA batteries like your LD12.I was just researching. I have the LD12. I am considering adding the LD22 and/or PD22 to the collection.
Does this light use the same head as the LD12?
I was just researching. I have the LD12. I am considering adding the LD22 and/or PD22 to the collection. In comparing the lumen levels of each mode, I'm thinking all 3 have a different head. if they were the same head, I would expect at least medium and high would match up between the PD22 and LD12. I'm just guessing of course.
max, high, medium, low:
LD12: 115, 60, 27, 3
PD22: 190, 95 ,46, 8
LD22: 190, 92, 42, 3
from the BatteryJunction descriptionTenergy RCR123A 3.0V 750mAh Rechargeable LiFePO4 Li-Ion Batteries
Working Voltage:3.2V and Peak Voltage: 3.6V
Tenergy Rechargable 123's have a higher initial voltage, closer to 3.5 volts i think.
The dual button setup is not my cup of tea. I like front switches when applied well, but having to operate 2 switches to use the light seems like unecessary complexity.
-- Adam
Normally the PD32 would be the perfect compromise, but I'm trying to get away from 2 cell cr123 lights and Li-ion. I love the extra brightness in the small size, but sometimes I feel uneasy about them when my family might use the lights.Unless size is critical, out of the PD22 and LD22, I'd personally go for the LD22: better runtimes and uses AA batteries like your LD12.
The PD32 looks like a good option though: works with both CR123s and 18650s!
As regulation suggested in his post, holding it overhand with thumb on the tailswitch and operating the sideswitch with another finger works nicely.
I have the LD12 since it came out and recently got the LD22. I don't have any bad feelings about the side switch. The rubber boot is low profile and seems sturdy and the switch has a nice 'silent click' feel to it. I have not experienced any jumping of modes that sloppy contacts might produce. Only time will tell for sure. I would worry more about the tail cap. My LD22 came with defective tail cap. (quickly replaced by Fenix Outfitters) My original very first Fenix had a bad tail switch and I have had a bad switch on a Surefire too. So I worry about clickies in general. I think the PD22 would be as solid as any other Fenix lights.How durable do you think the light is? Side mode selector possible fail point? I think they should get rid of the high mode and only have low, medium, and turbo.
