Some early results are in! Jusy got my Ns with K2 (UXOL)and the current "std" reflector a couple days ago. Did a few comparisons of my May vintage T-bin Ns with the Joker turned down reflector, the K2 light as received with the newer "std" reflector, and the Ns K2 with the reflector switched out to the Joker. The graphs do most of the talking. After getting a new U-bin LED in the next couple weeks I plan to update all this and post in the reviews section, but thought some of you might be interested....
First the light brightness data / summary. Not a huge difference visibly in the K2 vs the T, but the center beam brightness does improve with the K2 vs the T, and the Joker vs the std reflector:
Beam profile: raw brightness (Lux at 1 meter) vs. beam angle at 2 minutes after installing a fresh R14250 battery:
Beam profile: the same but as a relative % of max (beam center) brightness. This one IMO gives the best indicator of relative beam design, and it's more clear from this how the Joker gets more output concentrated in the center region of the beam:
Calculating how this all rolls up into output (Lumens) within the range of beam angles (the far right number is the total light output). The as shipped K2 with std reflector beats the Ns T with Joker, and the K2 with Joker beats everything. WOW!
Finally runtime on the K2
[UPDATE 8/26] - completed the test on hig, and for comparison pulled up some prior tests on the a TWAJ and UWOJ LuxIII Ns (Joker reflector on all). Interesting - on High K2 kills T, less runtime than U but much stronger during the runtime. Great runtime/output combo on not-so-low. I'll take the K2! Guessing I could run for an hour or so on not-so-low including many bursts on high of a minute or so.
Tint is good / natural looking. No obvious beam artifacts.
It gets VERY hot still on the high setting after a few minutes. I only ran the K2 light to 3 minutes and it was nearly impossible to pick up. Holding in your hand will help but I don't think it's a good idea to run on high more than a few minutes. Heat is no problem at all on the not-so-low setting.
Overall I am VERY impressed with the K2 - and with the joker it's a total ++ winner. Incredible output on high for this tiny thing, and the good/useful output lasting over 1 hour on not-so-low is a nice improvement IMO. Plenty of spill and great wide beam. Who says this light is not practical??
These Ns's just keep getting better - nice job Rob! (but man I like that Joker - to bad they are no longer available).
