thedoc007
It will do 69mm cells easily. I'm betting even the 70mm FastTech Panasonics would be OK, although there would be a lot more tension in the spring. 68mm is probably ideal.
Can anyone comment on the red led?
It is red-orange, or a true deep red that doesn't effect rod vision.
Thanks in advance!
How can I quantify the red? It is pretty red, but I don't know if that precludes it from being red-orange.
That's a good question, I guess you have to have a light with the red orange emitter to compare. The red should be a deep red, and not red-orange. So simple its hard to explain.
Looks like its a red emitter with a red diffuser over it??
T45C throws better than EA4? Interesting because manufacturers claims are almost identical (800lux/1m more for EA4).
How does the T45c compare to the Fenix tk35?
...could you tell us how beam pattern of C21C compares vs ZL SC600? Is it also very floody or gives more throw?
The beam pattern of C21C is very similar to that of my SC600. Actually, my first-generation SC600 is slightly throw than C21C.Juplin, could you tell us how beam pattern of C21C compares vs ZL SC600? Is it also very floody or gives more throw?Also - how exacly low voltage indicator works in C21C?
The screws of C21C are also used in many eyeglasses frames. Under urgent situation, you may also contact local eyeglasses stores for substitutive screws.Alarmingly, I discovered one of the screws fell out on my C21C. I asked Craig at Illumination Supply to send me a new screw but in the meantime I decided to put blue loctite on all my screws. I'd advise the rest of you to keep an eye on your screws!
The C21C beam is not as clean, either, to me that is the biggest difference. The SC600 is almost a perfect even circle, and the C21C is not.
